This block works properly.
When Mouse placed over the UV, does not display High UV, only current reading.
Would it be possible in a future update to get the STATUS LED like the plug in has, so you can click that and reload just the one block and not the whole page?
SSgauges Block
- BobW55
- Station model: Davis Pro2
- Software: Cumulus
SSgauges Block
Davis Vantage Pro2 wired
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
Re: SSgauges Block
Im not sure why you would want to have the block reload upon clicking. There is already a feature for auto-reload of the data, which seems as a much more elegant solution to me.
- BobW55
- Software: Cumulus
Re: SSgauges Block
There is a time setting for the PLUGIN, does this also affect the SSgauge block?
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
Re: SSgauges Block
Which time setting do you mean, in general yes, the block uses setting from the plugin
- BobW55
- Software: Cumulus
Re: SSgauges Block
Ok, I understand.
I increased the time in the plugin. Problem solved.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
