I have issue where when i run the Test Cumulus script i get this error:
The parsed date is 2017-10-21 10:57, current time is 2017-10-21 10:57
There seems to be a problem with the date and time. Either it has not been parsed correctly or it is a date/time in the future! Check the format you specified and also the actual values.Also could this rule be relaxed somehow little bit?
