Hello again,
Years ago when I was using the Carterlake template I seem to remember there was a "printable forecast" page which would produce a 5 or 7 day forecast flyer which could be printed out and then you could maybe pin it up on your work notice board for example. I think at the time it used the forecast from WU or Wxsim if you had it. I have given up using WU as an option in MT and I don't have wxsim, but would something similar be possible in MT?
Printable forecast
Re: Printable forecast
Im afraid this is exactly the same issue as in the other thread - this is now available - you can generate a PDF forecast, ideal for printing. If this does not work, then the only option would be simply printing the page where the forecast is shown on your site using the default browser printing dialog
