Tip: Adding Sticker to Forum Signature with Hyperlink
Chat about anything... (as long as it is a sensible debate :-) )
Post by MonyMony » Thu Oct 12, 2017 12:21 pm
Hi All,
Wanted to pass on a small tip. For those of you that have added your template Sticker to your forum signature, it is possible to turn the graphic into a hyperlink. You can see this in action if you click on my sticker it will link you to my page. What you need to do is format the signature like this:
[url=http://www.cecilweather.com][img]http://www.cecilweather.com/weather/cecil/plugins/stickers/stickerInteractive.php?text=Cecil%20County%20Weather%20-%20Elkton,%20Maryland,%20USA&image=01&border=2&type=interactive&dualUnits=1[/img][/url]
The key is to add the [url=http://{your site}] before the [img] and at the end of the signature string to add [/url].
Hope this is helpful to someone :lol:
Jay
Re: Tip: Adding Sticker to Forum Signature with Hyperlink
Post by Johnny » Thu Oct 12, 2017 12:33 pm
Brilliant - it works, thanks for this suggestion.
Luc
Software: WeeWX
Post by Luc » Thu Oct 12, 2017 1:03 pm
Perfect! Thanks a lot for the tip!
iatros
Post by iatros » Fri Oct 13, 2017 6:15 pm
Nice, thank you!
Language Admin für Deutsch
Post by Jachym » Fri Oct 13, 2017 6:39 pm
In case you want to try more tags, look up BBCode, this is what the forum uses ;)
meteocaldas
Station model: OS WMR-88A
Post by meteocaldas » Fri Oct 13, 2017 8:24 pm
Jachym wrote: Fri Oct 13, 2017 6:39 pm In case you want to try more tags, look up BBCode, this is what the forum uses ;)
Thank you soooo much Jachym.
Now it is much easier for me to understand how to work with the tags :-)
I was already using the sticker hyperlink since the early days of the forum (thanks Kocher for teaching me!), but I also have to thank MonyMony for publishing this very usefull tip in the forum. Thanks.
cw3beck
Post by cw3beck » Sat Oct 14, 2017 12:30 pm
Thanks for the tip, Jay! I've been trying to figure this out for the last couple of weeks !
John B
Weerstation Afferden
Post by Weerstation Afferden » Sun Oct 15, 2017 5:48 pm
Thank you, it works fine.
Is it possible to translate the text in another language?
meteocaldas
Post by meteocaldas » Mon Oct 16, 2017 1:44 am
Weerstation Afferden wrote: Sun Oct 15, 2017 5:48 pm Is it possible to translate the text in another language?
Jachym is the right person to answer that question, but I tried to do it and could not find any other solution than replacing all the ocurrences of the word "today" by the portuguese word "hoje" in stickerInteractive.php, like in this code example:
Line 579: textCenter($png_image,($width/6 * 2)+$widthShift, $recordsTopHeight1, ("Hoje"), 3, 8, $mainColor, 0);
Post by Jachym » Mon Oct 16, 2017 7:24 am
yes, correct, in the interactiveSticker.php you can replace the abbreviations with your own text
Post by Weerstation Afferden » Mon Oct 16, 2017 9:43 am
Thank you meteocaldas, it works fine...
Post by MonyMony » Mon Oct 16, 2017 8:59 pm
I am glad to see that my tip has been so helpful! :D
martymoose
Station model: Maxion
Software: Weewx
Post by martymoose » Mon Nov 06, 2017 7:48 pm
works here as well great work
thanks
