Dynamic Graph
- wxthomson
- Station model: Davis Pro 2
Dynamic Graph
The x axis seems to be in Z time and not local time.
Is there a reason for that?
- wxthomson
Re: Dynamic Graph
Additional info
Occasionally the block will load with vertical graph lines for times.
When it does this the time is local.
Mostly, it loads without the vertical lines and it loads as local but reverts to Z time after about 30 seconds.
Re: Dynamic Graph
That´s strange, does it do it in the DEMO too? Because I cannot replicate it, I see the times always correctly on my test server. See if you can replicate the issue on the demo site.
- wxthomson
Re: Dynamic Graph
I must be missing it but I don't see the Dynamic Graph block in the demo
- Johnny
- Developer
Re: Dynamic Graph
- wxthomson
Re: Dynamic Graph
Thanks, but that's the Interactive Graph
- wxthomson
Re: Dynamic Graph
Okay, I'll just delete it from my site.
I'm happy it works for you.
Re: Dynamic Graph
I asked you if you could check if the DEMO works, you never replied to that question and instead say you will delete it. It is then hard to help you, and not to mention that it would be nice if the problem was solved for everyone. Deleting it is not a solution.
- wxthomson
Re: Dynamic Graph
Yes, of course you are correct.
yes, the demo works for me.
on my site, the time reverts to zulu at the first up date whatever that may be set to.
Re: Dynamic Graph
OK, can you post a link to your website then? I will look at what's going on
Re: Dynamic Graph
Fixed
Dynamic Graph 2.1
Dynamic Graph 2.1
- Luc
- Developer
- Software: WeeWX
Re: Dynamic Graph
On my website the Dynamic Graph looks a bit funny for Wind.
Partly the graph show 5-minutes data, partly the graph show 2.5-seconds data.
Also: incidently the graph starts at 1970.
Re: Dynamic Graph
yes, that unfortunately is because the first time the graph loads, it has to get past data from the database (i.e. 5 minutes). Then the next points are already added from API (which you update more frequently) and because you use extremely short update times (3s) it then creates this...
- PaulMy
- Station model: Davis VP2 Wireless 6152
- Software: Cumulus
Re: Dynamic Graph
I have added the dynamicBlock and it doesn't seem to behave correctly. When it first loads it shows correctly for a few seconds and then shows a graph with the axis as years. In setup I have cumulus and the path ../weather/realtime.txt (http://www.komokaweather.com/weather/realtime.txt)
p.s. Jachym, I have make a temp indexDesktop with just just a few blocks so you can see it quicker... www.komokaweather.com/j-template
Paul
Paul
Re: Dynamic Graph
Paul use the API, everyone should now be using the api, I should have deleted the Cumulus option
- PaulMy
- Software: Cumulus
Re: Dynamic Graph
What API key
Paul
Paul
Re: Dynamic Graph
No Api key, we are talking about Meteotemplate API. Set the block data source to API. Do not use Cumulus
- PaulMy
- Software: Cumulus
Re: Dynamic Graph
Ok, I think I got the message, use the word api instead of cumulus. Now seems fine.
Paul
Paul
Re: Dynamic Graph
OK, yes, sorry for the confusion. I made a mistake in that I didnt delete the cumulus option, the block now works with the api exclusively.
