WeatherLink.com 15 minute updates to Weather Underground
RobF
Software: WeatherLink.com
Post by RobF » Mon Nov 06, 2017 10:31 pm
I'm about to run the install. I'm concerned that the Weather Underground data is updated every 15 minutes (more realistically it is 15 to 25 or so minutes). I do run WeatherLink 6.0.3 software on my PC and manually upload archives that are in 5 minute intervals. So there is a mix of 5 and 15 minute interval data on Weather Underground.
I think I'll run the install and see how it goes. Likely the 15 minute updates will be norm if I am too busy to upload archives manually.
Any thoughts on whether I should do the reformat?
Re: WeatherLink.com 15 minute updates to Weather Underground
Post by Jachym » Mon Nov 06, 2017 10:47 pm
WU normally saves data in 5min intervals, why do you send it in 15?
RobF
Post by RobF » Mon Nov 06, 2017 11:49 pm
We have a Davis Pro 2 Plus that uploads every 5 minutes to WeatherLink.com via Vantage Connect (a cellular connection). Unfortunately as we have discovered, WeatherLink.com only sends data to Weather Underground every 15 minutes, and it is not exactly 15 minutes as it can take 25 or more minutes at times.
The WeatherLink software on my PC is able to retrieve the data from WeatherLink.com and it has the 5 minute data. So I can manually upload that when I have time. So that is why there is a mix.
The install seemed to go well. It appears the data import from WU is a mess. I'll probably wipe it out and start over.
Post by Jachym » Tue Nov 07, 2017 2:14 am
Use the wlip plugin
RobF
Post by RobF » Wed Nov 08, 2017 1:42 pm
I have the Plugin installed, but how do I get to a setup page for it. If I go to the Plugin setup, I see it in a list but there isn't anything I can click on that I can see.
Post by Jachym » Wed Nov 08, 2017 3:49 pm
it is not something you see, you provide your WL details to connect to your WL data and then set a cron job for the updates (see the plugin documentation). There is nothing to "show", it runs in the background and updates your database
RobF
Post by RobF » Wed Nov 08, 2017 6:48 pm
OK the documentation says it needs my WL.com username and password, but doesn't where to set it.
UPDATEL I found it in the setup.php file.
Post by Jachym » Wed Nov 08, 2017 6:49 pm
in the settings for that plugin
RobF
Post by RobF » Wed Nov 08, 2017 6:55 pm
There are no settings that I can set up other than editing the setup.php file. I see in the script it looks for "settings.php" but there is none.
Post by Jachym » Wed Nov 08, 2017 7:02 pm
no, you need to go to the Plugins setup page and select it there and it will create the settings file. Never go to the code. The template uses GUI for everything, you should never go into the code unless you want to change something and know exactly what you are doing
RobF
Post by RobF » Wed Nov 08, 2017 7:06 pm
I haven't changed it yet. By reading the code I assume it is "supposed" to create its own settings file.
However, when I go to the Plugins page I see it listed, but there is no link, no button, nothing that would start an action.
I'm in IE, I'll try a different browser...
RobF
Post by RobF » Wed Nov 08, 2017 7:14 pm
Tried different browsers, nothing to get the setup going.
Mousing over the name of the plugin doesn't give anything.
Post by Jachym » Wed Nov 08, 2017 7:17 pm
Make sure that inside the plugin folder you have a setup.php file and it is readable
RobF
Post by RobF » Wed Nov 08, 2017 7:38 pm
It is there, permissions look good.
I did try to run it and got a fatal error:
Fatal error: Call to undefined function metaHeader() in /home/beachre2/public_html/weather-station/plugins/wlIP_4.0/wlIP/setup.php on line 39
Post by Jachym » Wed Nov 08, 2017 7:46 pm
that would suggest the plugin is not in the right location because metaHeader is loaded by the header on line 13
RobF
Post by RobF » Wed Nov 08, 2017 7:53 pm
This is on line 39:
<?php metaHeader()?>
Post by Jachym » Wed Nov 08, 2017 7:55 pm
yes, this function is loaded by the header.php which is loaded on line 13.
Try re-installing it, I just tested it myself and it works fine and no-one reported any problems with this one
RobF
Post by RobF » Wed Nov 08, 2017 8:12 pm
Reinstalled and it worked. First time I had uploaded the wlIP_4.0 and the wlIP folder. This time I just uploaded the wlIP folder and the Create Settings magically appeared.
