Current conditions - not showing trends
I am trying to find out, why my current conditions block doesn't display trends (small arrows below numbers). Did somebody observe the same issue?
Re: Current conditions - not showing trends
1. check you have "trends" enabled in Current block settings
2. if still no luck, please post a link
Yes, trends are enabled, the link is: www.modrehory.sk/tpl/ Thanks!
The block seems to have errors, but it also seems to be modified, did you modify the code yourself?
Yes, but the trends were not visualized also before the modification
OK, well it is hard to actually tell because Im not sure about all the changes you made, all I see now is a Javascript error "somewhere" in that block
OK, I just added another temp sensor...
BUT: now I reinstalled the original block - and trends are missing too
OK now I see the JS error - it is because you have no pressure, this is causing problems
OK, I see. Thank you for advice.
No pressure means the block works in a limited mode and this causes issues with the trends
