I got a tip from Bluebear about the Github uploader. I have tried that. I'm doing something wrong.
Weewx 3.71 on a RaspberryPi3
WH1080 Station
Meteotemplate 16.0 Physalis
Here are my steps.
- I followed the directions on the Github.
I used the weewx_extension utility
[sudo] password for ron:
Request to install 'weewx-meteotemplate.zip'
Extracting from zip archive weewx-meteotemplate.zip
Saving installer file to /usr/share/weewx/user/installer/meteotemplate
Saved configuration dictionary. Backup copy at /etc/weewx/weewx.conf.20171126124036
Finished installing extension 'weewx-meteotemplate.zip'
- I then checked the weewx.conf on the Raspberry and made the appropriate changes for sever url and password.
I saved the weewx,conf file.
I stopped and restarted weewx
weewx.conf (Passwords and other information removed)
[[Meteotemplate]]
password = XXXXXXXXXE
server_url = https://xxxxxxx.com/template/api.php
The syslog reports the following.
Nov 26 13:50:06 raspberrypi weewx[7340]: wxcalculate: The following algorithms will be used for calculations: altimeter=aaNOAA, maxSolarRad=RS
Nov 26 13:50:06 raspberrypi weewx[7340]: engine: Archive will use data binding wx_binding
Nov 26 13:50:06 raspberrypi weewx[7340]: engine: Record generation will be attempted in 'software'
Nov 26 13:50:06 raspberrypi systemd[1]: Started LSB: weewx weather system.
Nov 26 13:50:06 raspberrypi weewx[7326]: Starting weewx weather system: weewx.
Nov 26 13:50:07 raspberrypi weewx[7340]: engine: Using archive interval of 300 seconds (specified by hardware)
Nov 26 13:50:07 raspberrypi weewx[7340]: engine: Using binding 'wx_binding' to database 'weewx.sdb'
Nov 26 13:50:07 raspberrypi weewx[7340]: manager: Starting backfill of daily summaries
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: StationRegistry: Registration not requested.
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: Wunderground-PWS: Data for station KALDEATS9 will be posted
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: PWSweather: Posting not enabled.
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: CWOP: Posting not enabled.
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: WOW: Posting not enabled.
Nov 26 13:50:07 raspberrypi weewx[7340]: restx: AWEKAS: Posting not enabled.
Nov 26 13:50:07 raspberrypi weewx[7340]: engine: Caught unrecoverable exception in engine:
Nov 26 13:50:07 raspberrypi weewx[7340]: **** No module named meteotemplate
Nov 26 13:50:07 raspberrypi weewx[7340]: **** Traceback (most recent call last):
Nov 26 13:50:07 raspberrypi weewx[7340]: **** File "/home/weewx/bin/weewx/engine.py", line 865, in main
Nov 26 13:50:07 raspberrypi weewx[7340]: **** engine = engine_class(config_dict)
Nov 26 13:50:07 raspberrypi weewx[7340]: **** File "/home/weewx/bin/weewx/engine.py", line 77, in __init__
Nov 26 13:50:07 raspberrypi weewx[7340]: **** self.loadServices(config_dict)
Nov 26 13:50:07 raspberrypi weewx[7340]: **** File "/home/weewx/bin/weewx/engine.py", line 141, in loadServices
Nov 26 13:50:07 raspberrypi weewx[7340]: **** self.service_obj.append(weeutil.weeutil._get_object(svc)(self, config_dict))
Nov 26 13:50:07 raspberrypi weewx[7340]: **** File "/home/weewx/bin/weeutil/weeutil.py", line 1132, in _get_object
Nov 26 13:50:07 raspberrypi weewx[7340]: **** mod = __import__(module)
Nov 26 13:50:07 raspberrypi weewx[7340]: **** ImportError: No module named meteotemplate
Nov 26 13:50:07 raspberrypi weewx[7340]: **** Exiting.
I'm missing something. It sounds like a module? it's asking for?
Any help appreciated.
Also I noticed watching the videos, that my update options don't show a Weather Display option, is that normal?
Thanks,
