Hiyas!
In the Main Setup, there is a section for Services. The Paypal and Dark Sky sections are self-explanatory.
What do the other entries actually do, and what information should be entered. Is this for URLs to those sites?
Thanks!
Jeff
"Services" in Main Setup
Re: "Services" in Main Setup
It is pretty much only used when you use the networks plugin.
For example, WU is your WU ID (if you send data to WU), WeatherCloud - again, your ID for Weather CLoud, if you send data from your station to them.
jeffb22
- Station model: AmbientWeather WS-1401-IP
- Software: MeteoBridge
Very cool - thanks for the fast answer.
I'm using a Meteobridge router device to push data to other networks, so I'll leave those alone for now.
