When selecting the North American IR + topography map I get the following error. I get similar messages with other maps.
Warning: file_get_contents(): SSL operation failed with code 1. OpenSSL Error messages: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed in /home/kq5s02/public_html/template/homepage/blocks/naSatellite/naSatelliteLoader.php on line 12
Warning: file_get_contents(): Failed to enable crypto in /home/kq5s02/public_html/template/homepage/blocks/naSatellite/naSatelliteLoader.php on line 12
Warning: file_get_contents(http://weather.gc.ca/satellite/satellit ... type=1070x): failed to open stream: operation failed in /home/kq5s02/public_html/template/homepage/blocks/naSatellite/naSatelliteLoader.php on line 12
Data N/A
naSatellite Block
nineback
- Station model: Davis Pro2
- Software: WeeWX
Re: naSatellite Block
I never received a reply to this but noticed there is a new naSatellite block available which fixes the problem.
Thanks,
Thanks,
It was a change in data source (EC again... ) so a general problem
