Hi guy,
I have a problem with a setup of meteotemplate.
After compiling a setup page when click the save button, I receved this error:
Warning: file_put_contents(../config.php): failed to open stream: Permission denied in D:\inetpub\webs\trilogysystemeu\meteo\install\createConfig.php on line 1022
Warning: chmod(): No such file or directory in D:\inetpub\webs\trilogysystemeu\meteo\install\createConfig.php on line 1023
and appar a popup with this error:
Config file could not be created! Check that permissions for the template root folder are set correctly to write files in there!
Ok the error il clear, my provider not permit a create file with a script, but I have this provider "Aruba".
Is possible to have a config.php file and fill in by hand ?
Many thanks.
Giuseppe
Error while create config.php
Re: Error while create config.php
if you cannot create any files by script then Im afraid there is no way you can use Meteotemplate. There are hundreds of files that need to be created and updated
I have never seen a provider blocking any file creation, is it a free hosting?
sky7176
- Station model: WMR100
- Software: Weather Station Data Logg
No, it's not a free host.
If I change the provider do I have to re-download the package?
Giuseppe
Giuseppe
sky7176
I wrote to Aruba technical assistance for clarification.
Giuseppe
Giuseppe
not really, if you have the download file in your PC (the original ZIP file), then you simply upload it to a new server
