Is there a problem with the CountDown Block?
BlueBear
Station model: Davis VP2
Software: WeeWx
Post by BlueBear » Thu Dec 21, 2017 9:04 pm
I edited the setup for this block and see that the Spring and Summer dates I entered show as counting up not down?
See right column about half way down at http://www.sanfordweather.com
Re: Is there a problem with the CountDown Block?
Post by Jachym » Thu Dec 21, 2017 10:22 pm
If the gauges count up it means you entered a date in the past
BlueBear
Software: WeeWx
Post by BlueBear » Thu Dec 21, 2017 10:46 pm
Here's what I entered
2017-12-25 00:00;2018-01-01 00:00;2018-03-20 11.16;2018-06-21 05.08
The first two count down, the second 2 count up??? Am I blind or what?
Gus
Station model: Davis Vantage Pro 2+
Post by Gus » Thu Dec 21, 2017 11:33 pm
Try replacing the periods . in the time with colons :
Davis VP2+, LabJack w/temp sensors & 1-Wire lightning counter on Trigkey G4 Mini PC, 12th Gen Intel Alder Lake N95 Processor, 16GB SDRAM, and 500GB SSD, Windows11
BlueBear
Software: WeeWx
Post by BlueBear » Thu Dec 21, 2017 11:41 pm
Thanks Gus, these old eyes of mine sometimes have problems seeing stuff like that on the screeen!
Fixed
Bill
Post by Jachym » Fri Dec 22, 2017 1:36 pm
thanks Gus, yes in PHP you must use a colon, not a period.
