Hi everyone,
Got a issue with the webcam plug-in, it's working perfectly before november 23, but from them, i see the calendar but it's looking nothing can be see after the 23.
My block webcam and the timelapse work fine.
Any Idea ?
Plugin Webcam Issue
Re: Plugin Webcam Issue
Just a thought, do you have some limitation with regards to number of files or size that can be saved on the server? Try deleting maybe a few images and see if they are replaced by new
blainec
I have a different issue.
All my images that are saved in the images folder are being saved with 0 size
Any ideas?
Any ideas?
This looks like the GD extension on your server is not working correctly, so the image is not processed, or the source image is inaccessible (try using relative path)
