Year Normals plugin
- jay_hoehn
- Language Admin
- Station model: Vantage Pro 2 Plus
- Software: WeeWx
Year Normals plugin
Jachym,
Would it be possible to add the number of rain days to the totals at the bottom of the rain tables? I realize that I can count them, but I'm lazy.
Thanks,
Jay
Thanks,
Jay
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Year Normals plugin
Yes. When I select rain I would like to see the number of days we have had rain.
Added
Annual Averages 9.0
Annual Averages 9.0
- jay_hoehn
- Language Admin
- Software: WeeWx
Thank you so much sir. This is what I wanted.
Jay
Jay
- Luc
- Developer
- Software: WeeWX
I always struggle to find this plugin, because it has three names.
The plugin is called: yearNormals
Jachym calls it: Annual Averages
In the menu it is called: Yearly averages
One more thing:
The Table section has many dark colored fields with black numbers inside (which are hardly visible from a distance).
One more thing:
yearNormals - this is the original namespace, which must not be changed for compatibility reasons
Annual Averages - is what I renamed it in v2 because these are not really "normals" - normal is a 30year period
- Luc
- Developer
- Software: WeeWX
Why not renamed it in 'Yearly averages' as it is named this way in the menu?
OK, this is how it arised:
- originally I called it yearlyNormals
This namespace must be maintained for compatibility reasons. Later I decided to rename it because this is not using normals. The fact it is called differently in the menu is down to the translation. Annual averages is something I wrote in my plugin database, the thing you see in the menu is how it was translated (in this case not by me)
