Station Deviation settings
- Reinhard
- Station model: Davis VP2 Pro wireless
- Software: WeatherCat
Is it possible to set the graph view as default view instead the Temp view? Thanks for reading.
- Bildschirmfoto 2018-01-03 um 11.51.33.png (80.1 KiB) Viewed 6096 times
- Reinhard
Re: Station Deviation settings
Lespius,
seems like no help on this one. So here is my own try, maybe you can help me a step further. What I have done so far within stationDeviationBlock.php is:
Set the mticon-graph to Active and copy and paste it to the first position:
Set the stationDeviationDivT to display none:
Removed display none from stationDeviationDivGraph:
And finally done some changes here:
Unfortunately I end up with no graph displayed, but at least with a blank block waiting on a click on the graph button. Anybody out here that can point me the way to display the graph as default?
<span class="mticon-graph stationDeviationParameterIcon stationDeviationActive tooltip" data-id="graph" title="<?php echo lang('graph','c')?>"></span>Code: Select all
<div id="stationDeviationDivT" class="stationDeviationDiv" style="display:none">Code: Select all
<div id="stationDeviationDivGraph" style="width:98%;height:300px;margin:0 auto;"></div>Code: Select all
$(".stationDeviationParameterIcon").click(function(){
$(".stationDeviationDiv").hide();
id = $(this).attr("data-id");
$(".stationDeviationParameterIcon").removeClass("stationDeviationActive");
$(this).addClass("stationDeviationActive");
if(id=="T"){
$("#stationDeviationDivGraph").hide();
$("#stationDeviationDivT").show();
$("#stationDeviationDivR").hide();
else if(id=="R"){
$("#stationDeviationDivR").show();
$("#stationDeviationDivT").hide();
else if(id=="graph"){
$("#stationDeviationDivGraph").show();
Highcharts.chart('stationDeviationDivGraph', options);
})- Reinhard
Thank you for giving us the option to make the graph as default. Much appreciated!
