Reformatting not working after April 1st 2016 anymore
MeteoTwischkamp
Station model: WH 1080 + RPI 3
Software: WeeWX 3.9.1
Post by MeteoTwischkamp » Sun Jan 14, 2018 11:27 am
It looks like the reformatting tool is not working anymore for my database. I used it a while ago to have the intervals of my large database (starting in 2006) on the same level (5 minutes) and that worked back then.
Until January 6th 2018 i used the import file option from Weather Display so that my logfiles are again in 1 Minute intervals.
Since i recently decided to switch to a raspberry which runs 24/7 (unlike my old laptop which was off during the night and during longer absence) data is now automatically updated by the api every 5-10 minutes so no need to reformat that.
What i want to do is to reformat the data between April 1st 2016 and January 6th 2018 to have five minute intervals. I followed the instructions in the wiki and got the " DATABASE REFORMATING...
DONE!" screen instantly. Checking the database after that, indicated that nothing has been done.
I guess this has to do that i had used the reformatting script already once- so is it possible to reformat the data a second time?
Best regards
Georg
"Deus mare, Friso litora fecit" (God created the sea, Frisians the coast).
Best Regards
Georg
Re: Reformatting not working after April 1st 2016 anymore
Post by Jachym » Sun Jan 14, 2018 12:17 pm
no, not currently and it is something I want to fix in v18.
However you should be able to do it yourself. If you use phpMyAdmin, you need to delete the table "new" and "alldata_bkp". Then the reformat will work again.
MeteoTwischkamp
Post by MeteoTwischkamp » Sun Jan 14, 2018 1:56 pm
Okay thank you,
I will try it then tonight when i'm back home. :)
Best
Georg
Best Regards
Georg
