Problem with [Weather / Outlook] Tab
Post by Dehatter » Sun Jan 14, 2018 10:10 pm
The METAR information shown on this page is not the correct data for the METAR closest to me.
Under sources the METAR is blank, and I cannot find where to correct this.
Please see picture.
Thank you!
John B
Re: Problem with [Weather / Outlook] Tab
Post by John B » Sun Jan 14, 2018 11:12 pm
G'day, Tom,
Have you set up in your main set up page the details for your local METAR?
Post by Dehatter » Sun Jan 14, 2018 11:15 pm
Yes
Post by Dehatter » Sun Jan 14, 2018 11:18 pm
It is the same on your page too. The data in current does not match your METAR info either.
Post by Jachym » Mon Jan 15, 2018 5:04 am
That data is from WU using their airport stations.... so same problem as with the other blocks/plugins.... WU
Post by Dehatter » Mon Jan 15, 2018 8:07 am
Thank you for the explanation.
Any chance it could be gotten from the METAR information either in the block or the main setup page?
Just wondering.
Post by Jachym » Mon Jan 15, 2018 1:15 pm
The metar reports are inconsistent and also often unavailable. I know this because when I was creating some of the METAR blocks and plugins it was a nightmare. And most importantly, there is no history data, the official metar sources only give current conditions, the plugin shows history as well. The historical data is provided as GBs large files which can no way be processed by a script.
Reinhard
Software: WeatherCat
Post by Reinhard » Mon Jan 15, 2018 3:44 pm
My workaround for this one is to quote out the "airport"-line in the source code.
Post by Jachym » Mon Jan 15, 2018 4:24 pm
Thats what I will probably do unless WU fixes it soon
