"Abbr" is showing up in certain blocks
jas340
Post by jas340 » Fri Jan 19, 2018 10:19 am
example "MaximumAbbr" in station data block. rain rate 0.00 "inch/habbr" in the Current Conditions block. This started several days ago.
Also "directionN" instead of just N for wind direction??
*just noticed this is only happening when using my Chromebook. Everything looks fine on my PC
http://horseshoebendidahoweather.com/te ... esktop.php
Re: "Abbr" is showing up in certain blocks
Post by Jachym » Fri Jan 19, 2018 10:53 am
Double check your language files and that you have selected language in the Main setup
jas340
Post by jas340 » Fri Jan 19, 2018 11:00 am
Jachym, your suggestion worked. Thank you.
