Got a request from a user last night, is it possible to add a graph with the 'wind direction' in Weather Station -> Interactive views -> Interactive graph ?
Luc
wind direction Interactive graph
ON1GL
- Software: Meteotemplate/MeteoBridge
Re: wind direction Interactive graph
the problem with wind direction is the aggregation process. You cannot average the values like you average numbers.
Eg:
Wind direction 359 and 1° are both almost exactly N.
If you make an average you get 150 which is exactly S.
The numbers for Interactive graph are calculated by MySQL to make them fast enough and the averaging of MySQL in this case would fail because it would be misleading. PHP can use some very complex trigonometric calculations which are used in some reports etc. but they take too long to calculate for the block especially for longer intervals, which is why I did not include it
Eg:
ON1GL
on the 'mobile' page there is a graph like this with the bearing and it runs fast
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
My site has a bearing graph both mobile and desktop.
I cannot load your site, ON1GL for some reason.
ON1GL
very nice Tom, what is the name of that block ?
Luc
ON1GL
was to fast (happens sometime), found it.
Thanks for the info
Luc
