Any chance of adding UV to the database. I used the suggestion I read in the forums to add it to the current block, but that does not store the data thus it is not tracked or reported in any station table (other than current).
Add UV to the database
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: Add UV to the database
well...
So I have kinda answered my own question. I see that though WU lists UV, AND it is included in the table, it is NOT included in the downloaded data, and therefore if I am to add the information, I have to do it from another source. It so happens that I have another source (Ambient) to manually import the data, but there is not a current way to do this automatically that I am aware of. Once again...thanks go out to WU.
it is possible if you use the direct API call (weather display, meteobridge, weeWx, weatherCat), where if you include UV in the current conditions file and also activate UV in the "extra sensors" section in the control panel, it will log UV to the alldataExtra table in the database.
- Dehatter
Just installed meteobridge. Actually pretty simple, and seems to working great. Feels good to get away from WU. We will see about its hardiness. so far so good for the first hour. lol
