Hi.
Since some months ago my all data table isn’t getting updated by the cron job I used to use.
Looks to me like there are at least three ways to upload data:
- The cron job way
- The github utility
- The WeeWx built in feature
Witch one should I be using and where can I find the instructions to setup it?
Looks as in my searches I’m getting a lot of outdated information and I don’t know which one to follow.
Thank you in advance.
Mario
WeeWx data to Meteotemplate (witch method?)
Mariete
- Station model: Davis Pro 2
- Software: WeeWx
Mariete's Weather Station at: https://emariete.com/meteo
Mariete
- Software: WeeWx
Re: WeeWx data to Meteotemplate (witch method?)
I installed the matthewwall/weewx-meteotemplate package from github and looks like Station is receiving data but I would like to know if this is the recomended way of doing it or if I should switch to some other method.
Thank you.
Thank you.
- Luc
- Developer
- Software: WeeWX
When you are using weewx for gathering data from your weather station, the weewx-meteotemplate uploader from Matthew Wall on github is the proper way. The weewx data will be sent to meteotemplates api. No cron job needed.
Currently there is no weewx build-in function for meteotemplate; you will need to install the github utility.
For your information:
Matthew Wall is developing a general upload utility for 'missed' data, which may be available in a new version of weewx. This utility must be called with a start and end date and then will send all available data to configured programs like meteotemplate or others.
Luc
Luc
