Hi Jachym,
You've added "update Menu" in the Admin tab. Would it possible to have a "update language" link also (for the default language of the template)? This would make it a lot easier.
Best regards and again thank you for all your work
Martin
language file updater
- meteocaldas
- Language Admin
- Station model: OS WMR-88A
- Software: Cumulus
Re: language file updater
I also vote on that excelent idea
hi,
yes, in general updating anything directly poses 3 issues:
1. load on my server
2. problem for people using https (because my server is http)
3. file size (in this case not an issue but in general, large files, including some plugins, template etc. cannot be updated like this because unless you are using your own server, your provider will have fixed maximum execution time)
Some of these issues are a major problem, others might be possible to solve, I will have to see.
- meteocaldas
- Language Admin
- Software: Cumulus
Ok Jachym, I understand.
Sometimes you have to apologize that for a begginner like me, everything always seems easy if it going to be done by a "genius" like you
of course and some of the problems are not unsolvable, it is just a matter of testing out what works and what does not.
