Update setup can’t find realtime.txt
shawn
Station model: Davis Vue
Software: CumulusMX
Post by shawn » Thu Feb 01, 2018 11:26 pm
I fill in the path of my realtime.txt but when I hit test button it says. Unable to load conditions from the path specified.
What am I doing wrong:-/
Re: Update setup can’t find realtime.txt
Post by Dehatter » Fri Feb 02, 2018 1:57 am
I do not recall entering such a path. Where did you enter this?
Perhaps it is only because I have only used WU and meteobrdge, and this is part of a different setup routine.
Post by Jachym » Fri Feb 02, 2018 5:26 am
try using relative path, some servers dont like absolute paths starting with "http://
Use
../ for one folder up
shawn
Software: CumulusMX
Post by shawn » Fri Feb 02, 2018 12:15 pm
Path is evesham-town-weather.co.uk/weather/Cumulus/realtime.txt
I can’t even see it in a browser either. Not sure what I have done, i can access anything in template folder. Might be something simple but I can’t find it :-/
Cumulus folder has all the cumulus webpages but can’t access them either all being updated every 5 mins.
Post by Jachym » Fri Feb 02, 2018 12:32 pm
I would need to see URL of your realtime
shawn
Software: CumulusMX
Post by shawn » Fri Feb 02, 2018 12:54 pm
I think that’s the problem it’s not working or I’m just being a complete idiot.
www.evesham-town-weather.co.uk/weather/ ... altime.txt
Or
home720107234.1and1-data.host/weather/Cumulus/realtime.txt
But I just get a blank page or forbidden page
I’ve messed up the site index maybe? Tempted to delete everything on the server and start again :-/
Post by Jachym » Fri Feb 02, 2018 1:40 pm
dont delete the template, you need to fix the realtime and this is done in Cumulus
shawn
Software: CumulusMX
Post by shawn » Fri Feb 02, 2018 2:31 pm
All cumulus files are updating. When I get home I’ll pm you my login details
Post by Jachym » Fri Feb 02, 2018 3:40 pm
I need a link of realtime.txt, which when clicked will show a single line with current conditions, thats what you need. Until then nothing can solve it in the template
