2 questions_
1) Can you refer to a standard block from a menu? As in can I open meteorsBlock from the astronomy tab?
2) Are there any directions for the stickerInteractiveAnim.php plugin? I have guessed at a few parameters, but not been successful.
Sorry to bother-
Advanced Setup Questions
- jay_hoehn
- Language Admin
- Station model: Vantage Pro 2 Plus
- Software: WeeWx
Re: Advanced Setup Questions
Tom,
I can't answer your second question, but with the first you can not use a block as a plugin. Blocks need elements of the home page to operate.
Jay
Jay
Correct, block is a block and will only run from within the homepage, it cannot be run from a menu and I do not consider adding this because it would only bring confusion.
StickerAnim - this was an experimental script which Ive written for myself to make my sticker a bit different. It is not meant for use so there are no instructions how to use it. You would need to modify the code a lot from inside the PHP
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Only 5 hours later....I got the Anmi to work they way I wanted.
lol.....
lol.....
It is easier when you dont use the picture. Please dont post any tutorials, that script was not meant to be public, I accidentally included it in the download file.
- Dehatter
I won't. It was more complicated than I thought it would be, but I am stubborn and bullheaded, with a touch of OCD.
