Hi, I have installed the last version of the script, when I go to the Block install page I don't see any block, the list of block is empty.
Any suggestion?
Thanks, Alex
Block install page issue
- iatros
- Language Admin
Re: Block install page issue
Hi Alex
sorry for that question - did you download any blocks already ....?
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
When you say you have installed the latest version of the script, are you talking about the template?
If you are, you have to download the blocks you want from the block page.
Extract the actual block from the .zip file.
Upload the block to /homepage/blocks folder on your server.
Then you can use it.
There are videos on youtube that make it really easy.
Alex
Yes, I have downloaded some blocks and installed it manually.
I have other installation of the template and in any of them I can see the complete list of the blocks for download it directly
I use the last version of meteotemplate (V.17)
Bye, Alex
OK, can you post the exact path where you inserted the blocks and the exact path to one of the namespaceBlock.php files?
