Block - Current
TreeBee
Station model: Aercus Pro Weather Ranger
Software: Wunderground
Block - Current
Post by TreeBee » Tue Feb 20, 2018 6:31 pm
I have version 23 of the current conditions block installed with the 17.0 Nectarine template.
The block has stopped updating data with the time stopped at 18.05
http://www.treebee.net/indexDesktop.php
Everything else appears to be working okay and updating, gauges and current data link from the weather station tab. Have checked WU and CRON both are working fine.
Re: Block - Current
Post by MonyMony » Wed Feb 21, 2018 2:13 am
Took a look from here and your current conditions look, well, current. I know for me every once in a while something goes strange and gets stuck in the browser cache and cause the Current Conditions block not to update. I would suggest flushing the browser cache and then reload your page to see if that makes a difference.
Good Luck!
Re: Block - Current
Post by Dehatter » Wed Feb 21, 2018 4:12 am
When I updated the block, mine got stuck too. I went to edit on the block install page and just saved the configuration file without changes and it started working again.
Re: Block - Current
Post by Jachym » Wed Feb 21, 2018 7:37 am
Yes, it is necessary to update the settings file. The block does not tell you you need to do that because the settings file is already there, in this case you need to specify which parameters to show, if you dont do that it will show none
