Icon Issues?
marciealana
Software: meteobridge & WU
Icon Issues?
Post by marciealana » Sun Feb 18, 2018 5:09 pm
I've almost got my page completely set up, but sometimes icons are showing up as garbage. This is close to guaranteed if I am coming to the page from a link or a redirect, and clicking on home (which is just a box until the reload) will reload and everything's just fine.
For example: on first load, this is what current conditions are likely to look like:
But after clicking on the home icon, it turns into:
The whole page can be found at http://redwoodserenity.com/weather
Any ideas why this is happening?
Fraggboy
Software: Bloomsky
Re: Icon Issues?
Post by Fraggboy » Tue Feb 20, 2018 3:00 pm
I've seen this before when I first setup my page.
Your answer is in the WIki, specifically on this page: http://meteotemplate.com/web/wiki/wiki3GB.php
Click on the "NOTE FOR LINUX APACHE SERVERS!!!".
Re: Icon Issues?
Post by Jachym » Tue Feb 20, 2018 5:51 pm
Re: Icon Issues?
Post by Dehatter » Wed Feb 21, 2018 4:16 am
Not sure if it is related, but if I goto tempestasvililate.com (without the www.) I have problems. If I use the full address, www.tempestasvigilate.com, I do not.
Not an expert on this, but just saying what happens.
Edit: It must be related, because after I added the 3 lines of code it works without the www now.
Re: Icon Issues?
Post by Jachym » Wed Feb 21, 2018 7:36 am
the problem is in your htaccess file and this could also be causing the no/yes www thing
marciealana
Re: Icon Issues?
Post by marciealana » Wed Feb 21, 2018 1:34 pm
Fraggboy wrote: Tue Feb 20, 2018 3:00 pm Your answer is in the WIki, specifically on this page: http://meteotemplate.com/web/wiki/wiki3GB.php
Hmmm. I'm not at server root though -- I'm one level down from there (at html/weather/template). I'm also using the sort of redirect script that's recommended (sitting at http://redwoodserenity.com/weather/index.html).
marciealana
Re: Icon Issues?
Post by marciealana » Wed Feb 21, 2018 1:37 pm
Jachym wrote: Tue Feb 20, 2018 5:51 pm Please see
http://meteotemplate.com/blog/?p=1614
Bingo! This solved my problems. Thank you! i hadn't thought of scanning through the blog for solutions, I'd read the wiki and the FAQ, and was scratching my head :-/
marciealana
Re: Icon Issues?
Post by marciealana » Wed Feb 21, 2018 1:39 pm
Jachym wrote: Wed Feb 21, 2018 7:36 am the problem is in your htaccess file and this could also be causing the no/yes www thing
The problem was my .htaccess file. I'd tried every combination of with and without www, but that did not seem to help.
