Another broken plugin - the earthquakes plugin.
Doesn't return anything, just shows map.
I see it works on the demo but won't on my system for some reason...
EDIT:
This problem deals with cURL - since this script is downloading from a HTTPS site, if the Certificates list is not present (isn't installed by default by PHP), it will fail.
I found this error after doing some testing and debugging.
Fix:
Download certificate from https://curl.haxx.se/docs/caextract.html
Save it somewhere
Edit PHP.INI and change:
;curl.cainfo =
to
curl.cainfo = "C:\Program Files\PHP\cacert.crt"
(change the above line to wherever you saved it)
Make sure to rename .pem to .crt otherwise it won't work.
Earthquakes plugin broken on IIS - Fix
- dmgould
Re: Earthquakes plugin broken on IIS - Fix
It's working fine on both of my sites - the plugin and the block.
azchrisf
Guys I posted the fix, it's a cURL issue where the certificates aren't installed by default.
All fixed
All fixed
