Today I am working on importing data I have for (Date Time, TIN, HIN) into the "indoor" db table for the indoorData plugin.
All the data is in the 5-minute intervals as mentioned in the instructions.
Using the Indoor Data-Setup in the middle section of this page is where you can import the data (CSV/textfile setup). Upon pushing the Test File button I am returned with:
Loading CSV/text file from https://lobwx.com/template/install/extraData.csv
Cannot find the file specified. Check it has the right permissions and double check the path. If you are using URL try using relative path or vice versa.This plugin "indoorData" is working. I just need to add the extra two months of data to the indoor table. 20,000+ entries
~Bob~
