Interactive Graphs/Tables issue
swyman18
Station model: Davis VP2
Software: WEEWX
Post by swyman18 » Sun Mar 25, 2018 2:00 am
Hello... another "I must be missing something simple" question. I just installed and configured a fresh copy of MT onto my Linux VPS. I am feeding the template using WEEWX. The database/update setup went fine.
In general, the template seems to working but I can't seem to get interactive graphs or tables to work. I've tried using a couple of different browsers, so I'm sure I have something missing in the PHP or Apache configuration. Does something need to be configured for Highcharts to work?
One other strange problem I'm having is the Statistics section is not working for Precipitation only. It seems to be working for other data points. Also, I've confirmed there is definitely precipitation data in the database and I can see data under Current Conditions (Avg, Max and Total), so not sure why the Statistics section is not pulling the data.
If anyone has any ideas on what would be causing these issues, let me know.
Here is the site... note, I haven't setup any blocks or anything like that yet, just the default menu items. I wanted to make sure all the data is working before I customize it further.
http://vps.horkboy.com
Thanks!
Re: Interactive Graphs/Tables issue
Post by Jachym » Sun Mar 25, 2018 6:20 am
It looks like you have current data, but nothing is being saved to your database so you dont see any history data - graphs, stats etc. You need to check the MySQL details and the user permission for the database, alternatively look inside server error log
swyman18
Software: WEEWX
Post by swyman18 » Sun Mar 25, 2018 7:09 am
Hi Jachym, thanks for checking. MySQL is actually good, I imported some records for the past few months and I see all the data in the Database Editing section. I also am seeing some data under Reports, Trends and Statistics but seems like not for all data points. Also graphs are not generating for some reason.
I'll keep playing around with it, thanks anyway.
-Scott
Post by Jachym » Sun Mar 25, 2018 8:58 am
OK, please email me your admin password
swyman18
Software: WEEWX
Post by swyman18 » Sun Mar 25, 2018 9:30 am
Jachym wrote: Sun Mar 25, 2018 8:58 am OK, please email me your admin password
Sent... thanks!
