Due to heavy vind and vibration in the 5-1 acurite the cup that measure rain tilted several time and mesured rain half the day.
Total of 10mm
Is there an easy way to fix this in the database.
I have no clue to mysql and commands here
Roger
wrong rain today db
Re: wrong rain today db
use the Data edit feature in the Control panel
- bidouilleur
- Station model: Weatherflow
- Software: weewx
Hello Jachym
can I suggest something to make the editing easier
Yesterday I had many false rain data (testing the setup etc)
while the edit mode is pretty good, when you start to scroll down .. you loose the header with the explanation of what is what column ... could you make the data scrollable but keep the header fixed (bit like in Excel)
this is very difficult to make on a webpage, not impossible, but it is already in MT if you choose the fixed menu, so this would be another problem - users who have the fixed menu would see the menu instead,
