Current readings block only displays Celsius
aznetcowboy
Post by aznetcowboy » Mon May 07, 2018 4:54 pm
I like the "current" block but I only get Celsius reading, not Fahrenheit which is what I want. Is there a way to accomplish this or is this a block that only displays in Celsius?
Tom Wills
Kingston Knolls Terrace, Tucson, AZ 85710
El Gheko Neighborhood Weather Station: http://www.elgheko.us
El Gheko meteoTemplate Weather Station: http://www.elgheko.us/mtp/
El Gheko Neighborhood Association: http://na.elgheko.us
Certified Skywarn Trained Observer #1569
BlueBear
Station model: Davis VP2
Software: WeeWx
Re: Current readings block only displays Celsius
Post by BlueBear » Mon May 07, 2018 5:06 pm
Display units are set in the Main Setup! Look in the section labeled Units
aznetcowboy
Post by aznetcowboy » Mon May 07, 2018 9:00 pm
In the Main Setup Units section, both the "Database units" and the "Webpage default displayed units" are set to Fahrenheit. However, I see under Normal's section that the "Precipitation normals" is reset to "C" even after I set it to "F" and do a save.
Okay, I'm not sure what happened here, but now it is displaying correctly. The only thing I changed was the "Precipitation normals" back to "F"
Tom Wills
aznetcowboy
Post by aznetcowboy » Wed May 09, 2018 3:01 pm
Ah, Ha. Now I know what's going on with the current conditions displaying Celsius. It is Firefox's Quantum. They just did an upgrade to version 60 and now the icons display okay, but the current conditions are still displaying Celsius. With Chrome the current conditions display Fahrenheit. Looks like more work for Mozilla.
Tom Wills
Post by Jachym » Thu May 10, 2018 8:33 pm
That is very odd because the units are handled by server, not browser?!
Post by andyk1 » Wed May 16, 2018 4:30 pm
Also one thing I am thinking is if he set the main setup to "C" in the main setup then his datadase may be also be set to "C" if he wanted "F" instead of "C". May need to start all over with a new database but am not sure that is his problem with limited details.
