on my installation ( http://www.limbach-meteo.eu ) are some differences between Current Block and actual data from Weather Station. It's look like 1 or more hour delay for current. But the update interval is 60 sec. Datasource is weewx and Davis VP2, send Data over meteotemplate plugin every 60 sec.
Any hints for sync?
Michael
Differences between Current Block and Actual Data
Re: Differences between Current Block and Actual Data
The current block does not use database, it shows exactly what was sent by weewx directly, so you would need to check what exactly is WeeWx sending.
Check the content of meteotemplateLive.txt in the template root, thats the current data as sent by WeeWx
