Paypal - Error message *SOLVED*
DadOfZelda
Software: Meteohub
Post by DadOfZelda » Wed Jun 27, 2018 8:47 am
I tried to get the Paypal block work.
I have both tried with generated ID and mail but got the same error message (from PayPal) in both cases.
What I don't understand is if they mean my Meteotemplate site or Paypal site when they refer to "sellers site".
Well, I'm a newbie so there is possible a simple solution to this ;-)
Christian
kd7eir
Station model: Ecowitt Wittboy
Software: FOSHKplugin
Re: Paypal - Error message
Post by kd7eir » Thu Jun 28, 2018 3:06 pm
They are referring to the site that sent the request to them, so they are talking about your Meteotemplate website.
Post by Johnny » Thu Jun 28, 2018 3:13 pm
Hi Christian,
An obvious check I suppose, but you are definitely using the email address attached to your PayPal account?
DadOfZelda
Software: Meteohub
Post by DadOfZelda » Thu Jun 28, 2018 3:42 pm
OK, what I thought also. But now know, thanks!
Yes, I'ts the same mail.
I have had other CMS running with my account before (as Joomla and Wordpress) and then no problem to mail. So I don't think there is any problem with my service provider. But you should never say never ;-).
I read in some thread about a problem with the test (in the template, but that mail worked anyway).
Is it possible to trigger a mail in any other way? I suppose that field then must have my mail within it?
Christian
weather display
Station model: Davis VP2
Software: weather display
Post by weather display » Fri Jun 29, 2018 4:20 am
paypal has changed to needing TLS 1.2 on a server
on the 28 june
(i.e security layer)
maybe that is part of the problem?
DadOfZelda
Software: Meteohub
Post by DadOfZelda » Fri Jun 29, 2018 9:11 am
OK, hmm.
I tested to set up a blank page with the code from Paypal. Created a page in the same directory as the Paypal block.
Then all was ok. I was directed to PayPal with correct information. This with the same ID as I provided in config.php in the template.
Could it be some problem with the block? Or more likely, what do I do that is wrong? :-)
/Christian
DadOfZelda
Software: Meteohub
Post by DadOfZelda » Fri Jun 29, 2018 7:22 pm
Now it's working, did a workaround.
Within payPalBlock.php I change the code for $payPalType==Button from the original to the code I got from PayPal.
Understand this could be a problem if the Block updates and/or with a new version of the template. But could not see what else to do.
Now I have to figure out how to get PayPal to open in a new Window :-)
/Christian
