Current Condition -more-
Zedekia
Post by Zedekia » Thu Jul 19, 2018 7:35 am
I have a problem with this block. The UV max does not display the value.
Any ideas?
cu
Zedekia
Re: Current Condition -more-
Post by Jachym » Thu Jul 19, 2018 6:00 pm
Did you set up this sensor in the Extra sensors section? Because if not it is only being taken from the realtime values without being saved
Zedekia
Post by Zedekia » Mon Jul 23, 2018 1:04 pm
Hello Jachym,
pls. help me, where can I find the extra sensor settings?
CU
Zedekia
John B
Post by John B » Tue Jul 24, 2018 4:29 am
Zedekia,
I have no extra sensors, but I think you will find it in your administrator control panel in the data base section.
Zedekia
Post by Zedekia » Tue Jul 24, 2018 5:59 am
Hello John B,
thank you for your response.
The link
...template/update/apiSetup.php
does not work, because the file apiSetup.php is missing.
What can I do?
Best Regards
Zedekia
Post by Jachym » Thu Jul 26, 2018 5:46 pm
that file is in the download file, check that you uploaded it to your server, it could be that the FTP upload failed for that file
Zedekia
Post by Zedekia » Tue Jul 31, 2018 2:46 pm
Hi Jachym,
now it works. Thank you very much.
Zedekia
