I've installed the Steel Series plugin and block but they are not displaying data.
Is there a step by step installation guide for this?
Thanks,
Rik
http://mooseberryhollow.com/pws/templat ... esktop.php
Steel Series Gauges - Installing
Re: Steel Series Gauges - Installing
the gauges require at least one full day of data, in case you have no data in db for yesterday, wait for tomorrow and it will start working.
Lewiston
Excellent. Thank you!
Lewiston
Is this also the reason for the following error scrolling on my gauges page?
parsererror: SyntaxError: JSON Parse error: unexpected token '}'
Rik
Rik
Lewiston
Thank you. That was it.
- aznetcowboy
- Software: Cumulus
I am giving the steel gauges a try, but no luck so far. I have installed the ssGauges 3.1 into the homepape/block folder and the Steel Series 4.0 plugin into the plugins folder. After setting up both the plugin and the block, I am getting the following error displayed in my home page:
Block ssgauges not found. Check that you uploaded the block to the correct folder and also make sure you do not have a typo in the homepage setup.
Any ideas?
Any ideas?
Tom Wills
Kingston Knolls Terrace, Tucson, AZ 85710
El Gheko Neighborhood Weather Station: http://www.elgheko.us
El Gheko meteoTemplate Weather Station: http://www.elgheko.us/mtp/
El Gheko Neighborhood Association: http://na.elgheko.us
Certified Skywarn Trained Observer #1569
