https://www.pennlake.us/meteo/template/ ... /index.php
If you check the link above you can see that the map is not loading (at least for me).
I did not update and probably will not update my google api key, so if this is a google problem is there any other solution??
Probably Google Map API??? ISS Traker
yamiacaveman
- Station model: Davis Pro 2
- Software: Weather Display,Meteotemp
- LOBWX
- Station model: Ambient WS 1401-IP
- Software: MeteoBridge
Re: Probably Google Map API??? ISS Traker
I use Chrome and its the script not running it need you permission to do its thing. Look on the far right of the address bar and you will see what i mean.
- polbrieuc
- Software: Cumulus
Unfortunately, the site http://api.open-notify.org/ which is used by this plugin does not have a SSL version.
So there is nothing you can do for now (except potentially use a proxy but that gets a little bit more complicated)
More details here : https://discourse.processing.org/t/erro ... -json/4335
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Hola
for me it works with opera and firefox
disable https for it to work
I think you should change all http URLs by https in your script
Hello from France
Hello from France
MrFlash
- Station model: TFA Nexus
- Software: Meteohub
Is there any solution for the SSL problem?
Best regards,
Martin
Best regards,
Martin
- WessexWeather
Only just become aware of this problem affecting my site too. Has anyone found a workaround, or is it best just to remove the plugin?
I notice the Pollen Forecast - EU appears to have the same issue: -
https://www.wessexweather.net/meteotemp ... /index.php
Blocks from insecure sources on the home page (eg Blitzortung) seem to function okay, you just lose the padlock in the address bar, as does the Night Sky plugin (insecure sky map): -
https://www.wessexweather.net/meteotemp ... ghtSky.php
Simon (WessexWeather)
- WessexWeather
Is there a workaround to get these plugins working again Jachym, or anyone?
ph2
Are there any solutions how the plugin works with https (without proxy), possibly with an external link?
