sticker problem
blaineca
- Station model: Davis Pro 2
sticker problem
The data on the sticker will not display.
I have attached a image of what it looks like
Any ideas?
Any ideas?
Re: sticker problem
Did it work before? What data source do you use?
blaineca
Re: sticker problem
Yes, it worked for a long time. now it just stopped working.
For a data source I use meteotemplateLive.txt
Re: sticker problem
Were there any changes on your server made?
Re: sticker problem
If the plugin worked before and no changes were made to the code, then the only thing I can think of is that your server was for example upgraded to some newer version, which does not have certain extensions installed
blaineca
Re: sticker problem
It turns out that it has something to do with php 7.1. I installed 7.0 and it works
So I guess I forgot about a php update
Re: sticker problem
I dont think there were any changes which would make it non-functional in 7.1. It is more likely that the 7.1 installation did not include all the extensions as the 7.0 you had because I myself use 7.1 as well and it works. It uses for example the GD extension for handling images.
