Certain Blocks
boomie1977
Station model: Ambient WS-1002-Wifi
Certain Blocks
Post by boomie1977 » Wed Oct 24, 2018 11:37 pm
In certain folders of different blocks, in this case "current_24.1" do I need to go in and set the different settings. I am now using Weather Display with the Ambient Weather API and MAC Address for the device. So in my Weather Display I am actively seeing data on my desktop. How can or where should I go to make sure that this data goes to my template?
Re: Certain Blocks
Post by Jachym » Sun Dec 09, 2018 8:48 am
each block has settings, but update of the template is set up elsewhere globally for all plugins/blocks etc.
Re: Certain Blocks
Post by andyk1 » Sun Dec 09, 2018 10:18 am
First you need to get WD (Weather Display) to ftp (in you're WD settings) to you're MT (MeteoTemplate) site. I believe WD saves in txt file but it's been awhile since I messed with WD. Check the documentation but data needs to flow to your MT host server. The settings in MT you need are in Control Panel and then DataBase update or something like that. I'm sure Jachym knows where I'm going with this and he is better able to assist you.
