New host for template
mholguin
Station model: DIY
Software: DIY
Post by mholguin » Sun Jan 20, 2019 10:39 pm
I moved my database to a new server , with no issues. New server is more stable, so I figure I could move the template from the raspberry my sensors are currently hooked on to the new server. The plan is to let the respberry to solely update the database, and do all access from the new server.
Copied the template, and is running fine. I verified it is reading the database. Problem is, it shows the station as being offline (whilst the raspberry version is working fine), and live gauges shows no data. Current Data shows the correct information.
I haven't played with the template fir a while and I'm running black currant (if it is not broken, don't fix it!) and is the first time I switch to a new server. So I'm not really sure on what am I missing here....
Thanks!!!
Marino
gtstricky
Station model: Davis Pro2, Vue
Software: Weather Link 2.0
Re: New host for template
Post by gtstricky » Tue Feb 19, 2019 9:21 pm
Did you copy files over directly or did you do a clean install?
Also... what is the site address?
mholguin
Station model: DIY
Software: DIY
Post by mholguin » Fri Apr 12, 2019 11:09 pm
Ii just copied the template to the new location, as well as teh directories permissions.
My station is not reachable from the Internet.
Post by andyk1 » Sun Apr 21, 2019 3:23 am
Where are you reading the database from. Your local server or new host. You have to point MT setup "MySQL Database" to the location of the database.
