Current Data Not Displaying - RESOLVED!
cdarney3
Station model: Davis VP2
Post by cdarney3 » Sat Feb 09, 2019 9:23 pm
I've been having a problem with my current weather data not showing reliably in the Station Info and Graphical Views Blocks. Current info doesn't show up on the Graphical dials either. I can run reports on the month of February but show nothing after 2/2/2019. Even before that I noticed that viewing current data was sporadic.
I'm able to send data to other sites like WU and Awekas, etc. and it shows up properly. A "Check for Problems" in the Template section of the Admin page shows no issues.
Are there log files related to the template I could look at?
Any other suggestions what the cause might be?
This is the site: http://darney.org/weather/indexDesktop.php
...Chuck Darney
dmgould
Re: Current Data Not Displaying
Post by dmgould » Sun Feb 10, 2019 12:45 am
Make sure your meteobridge is sending data to the template. You can log into your meteobridge and check the Live Data tab for a green check mark next to Meteotemplate. You can also click the Weather Network tab and make sure you have green check marks on Meteotemplate uploads. If they are all green it's probably something happening on the server. If they aren't green check your upload URL and permissions.
cdarney3
Post by cdarney3 » Sun Feb 10, 2019 5:40 pm
EXCELLENT!!!
I did go to the Meteobridge device and found it was not connecting properly. I had changed the UPLOAD password (strangely enough on 2/2!) and neglected to change that password on Meteobridge.
I uploaded all missing data to my DB from Weather Underground and I now see the weeks data.
Thank you so much!!
...Chuck
