jquery error
staze
Software: Meteobridge Nano SD
jquery error
Post by staze » Tue Mar 26, 2019 3:56 am
Just curious if this is being worked on. When loading up MT, I see this error in the console:
"[Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4"
Thanks!
agallardo1980
Re: jquery error
Post by agallardo1980 » Tue Mar 26, 2019 6:09 pm
Hi.
I have this issue too. It is not exactly un JS error, but a Warning to use "async=true" param in XMLHttpRequest for AJAX updates. I don't know if sync calls it is necessary to Meteotemplate script because these could block to other after calls until the first is completed. Maybe Jachym can clarify this...
Re: jquery error
Post by Jachym » Tue Mar 26, 2019 8:21 pm
correct, this is not an error, just a notification to make sure this is what you intended to do -which it is
