So out of the blue the stationStatus, the stationData and the little banner in the upper left under the country flag that used to scroll current data have all stopped working. I use meteobridge to update the meteotemplate api and that is getting an ok, I ran the system checks they all check, the steel series gauges are functioning, however the 3 other blocks mentioned above have all of a sudden stopped, as if the main template thinks the station is offline. The scrolling current conditions doesn't show up anymore at all. I reset the homepage and re-entered in all the blocks, I went through a main setup script again and checked everything, and re-created it, all looks ok there. I deleted and re-uploaded the blocks, and re-created the settings files from scratch, still no joy.
Any help with what I can check to fix this would be greatly appreciated. The url is:
http://www.w1ape.com
Thanks in advance !
Joe
Some blocks think station is offline
- jay_hoehn
- Language Admin
- Software: WeeWx
Re: Some blocks think station is offline
I know nothing about meteobridge, but I would check your database for an incorrect date entry. Your history block is not updating and your station status block has the default system date. Check the database.
Jay
Jay
flaboye
- Station model: Acurite 5 in 1
- Software: meteobridge 3.3
HI Jay, yes the culprit was in MySQL I was starting to zero in on that due to the default date as you mentioned showing.
Thank you for taking time to reply !
Joe
Joe
- jay_hoehn
- Language Admin
- Software: WeeWx
Joe,
Glad you got it figured out.
Jay
Jay
