interactiveGraph Shows Only Spinning Icon
jdstevens
Software: WeatherLink
Post by jdstevens » Sun May 12, 2019 10:32 pm
interactiveGraph only displays the spinning icon.
The database is updating every five minutes. I can view it with Sequel Pro. Other blocks are displaying proper data. graphCombined is showing valid information.
??? Suggestions?
John B
Re: interactiveGraph Shows Only Spinning Icon
Post by John B » Mon May 13, 2019 2:47 am
Hello, JDS,
It seems at first blush that, if everything else is working as it should, then there might be something in your block set up for the InteractiveGraph that is out of kilter; perhaps an entry which is outside its built-in parameters.
You will find an image of the bottom section of my set up page here:
http://www.johnsblaxlandweather.id.au/I ... active.jpg
The image is missing the top of the page, but that is only relating to colours.
By all means click on the 'banner' at the bottom of this post to visit my site and see the interactive graph in use.
jdstevens
Post by jdstevens » Thu May 23, 2019 2:40 am
Thank you for the reply.
The graph has worked in the past. I'm not aware of any changes that caused the interactiveGraph to stop working. The settings are all default settings. Most other blocks and functions that query the database work properly. I have deleted and reinstalled the interactiveGraph, and it still fails.
I went through functions under the "Weather Station" menu. Most work. Some don't. It appears that the database in populated and function. However, the modules are not consistently working properly. I am considering reinstalling Meteotemplate from scratch. I'll keep the existing database and other infrastructure.
jdstevens
Post by jdstevens » Fri Jul 05, 2019 3:59 am
"interactiveGraph" continues to show only spinning icon. I've not figured out the problem. I had a suggestion that there is a bad parameter, but I've found no faulty inputs. The database is being updated. The "graphCombined" shows correct information.
http://wx.stevens.com
Asobig
Software: Meteobridge (Red)
Post by Asobig » Fri Jul 05, 2019 8:01 pm
From the debug screen in Chrome i see an error in parsing the Temperature parameter.
jdstevens
Post by jdstevens » Sun Jul 07, 2019 2:49 am
Thank you for looking for the problem with "interactiveGraph" on my site. Unfortunately, I don't know what to do with the information you provided. All parameters for the block are default parameters. I have deleted and reinstalled the block. Other blocks exhibit no problem displaying temperature information from the database. The "graphCombined" displays the temperature, and other information, in a different display.
jdstevens
Post by jdstevens » Wed Jul 10, 2019 10:10 pm
Fixed. I ran the following command that was provided by Jachym three months ago:
I ran the command immediately after he provided it. It fixed interactiveGraph and combinedGraph. Neither was working.
Later, interactiveGraph quit working, while combinedGraph continued to work. I mistakenly assumed that there was a new problem when interactiveGraph failed, while combinedGraph continued to work. My assumption was wrong. Immediately after running the command again, interactiveGraph started working, and combinedGraph continues to work.
John B
Post by John B » Wed Jul 10, 2019 11:19 pm
Well done, jds, a sterling job, sir. Give yourself a gold star and accept my congratulations. :)
