I'm strugling to import correct rain data. When I for the first time installed Meteotemplate and importated data, I haven't payed attention to the rain data. All data I have, since 2011 is ok, except rain. There is many days with wrong rain data, like 2 consecutive days with the same rain. I already try to fix, with Fixing database rain function...but it's not fixing.
I erased some of the wrong rain data and tried to import again all data with "Skip existing mode" and "Overwritte mode", but nothing changed. The rain data remain the same.
I tried to import from Wunderground and from CSV file (Meteohub files). No error message is shown, all works fine, but in fact, no data is updated.
The only way I can change rain data, is trought data base editing, but its a lot of work, edit each minute of 7 years...
How can I solve this problem? I have 6 PWS with many years of data, and now it's time to have the rain data correct, however, it must be in a not so difficult way.
Import correct rain data
fredericowessel
milesb
Re: Import correct rain data
Could it be similar to the carry over that some are experiencing even though using different source software to upload their data? You might want to review this thread.... viewtopic.php?f=56&t=1686&sid=19e2522ac ... 15f3943739
You could also try Control Panel > Database > Bulk Database Update > Check and Fix Rain.
