New problem....
Desktop site loads very slow
http://www.mckinneyfarm.com
Mobile version loads like it should. Site has been running well for over a year. How can I tell if it's a host issue or on my end issue? Ideas?
Slow loading logged in as admin *fixed*
mchd17
Re: Slow loading
Your page took about 5s to load for me
mchd17
Re: Slow loading
problem not solved
works fine if i am not logged in as admin. once i log in and try to view homepage, loads very slow. if i clear browser cache, site loads fast. ideas?
mchd17
Re: Slow loading logged in as admin *fixed*
Jachym had me disable auto update check in Main Setup. Worked!
- Station model: Ecowitt WS90
Just ran across your posts. Your page took over 5 sec. to load and looking at it I see not difference in most other sites. Looking through some of the feedback your Host provider sent there's not much you can change as all the links are dependent on others. Doing a screen refresh loaded a bit quicker but not by much. My guess is it's on the host server side. Maybe you can add memory from your host. It's an upsell thing and I'm not sure if thats even the problem but I would say that would be a start.
