I'm about to set up the meteotemplate, but I have the following problem, no file from the /icons folder are displayed
for example /icons/menuDark.png
Files from all other directories are displayed correctly, e.g. /admin/adminIcons/mainSetup.png
Now I have created a ticket with my provider and received the following reply:
"Icons" is a default folder of the Apache web server and therefore can not be used!
What options do I have now?
Can the folder be renamed? Is there a setting (a variable in the php scripts) where this folder is defined?
Thanks for the support
Martin
Pictures from the icons directory are not displayed
BlueBear
- Station model: Davis VP2
- Software: WeeWx
Re: Pictures from the icons directory are not displayed
Sounds like your hosting is a linux based one
Check the Wiki at http://www.meteotemplate.com/web/wiki/wiki3GB.php and click on the red link to
NOTE FOR LINUX APACHE SERVERS!!!
It describes your problem exactly and how to fix it!
Wib3434
- Station model: TFA Nexus, Homematic
- Software: wview
Thank you very much for the quick response, now the page works correctly.
I searched the wiki and the forum, unfortunately I did not see the note
Thanks Martin
Thanks Martin
