Slow loading site large db?
- livejerseyweather
Hi there. I have been having real issues with my sit not loading or loading very slowly. http://www.jerseyweather.net but I do have a database over 1.2million entries goinging back to 2005 and think this might be the case?
Hope someone can help
- wxthomson
Re: Slow loading site large db?
It loads for me in 14-16 seconds
- John B
G'day our Jersey wrapped friend.
Other than the missing second full-width block (DarkSky & MeteoBlue) which shows nothing at all other than the options button, it seems to be fine. The speed of loading, given your webcam and maps, also seems good to me.
- livejerseyweather
Thanks both I am not sure what is going on with the second block as looks fine to me. Hmmmm will look inot that. So that's a normal page load for a DB that size then?
- John B
Well, I don't know what happened yesterday, but your second block is now operating as it should.
I timed your site today and it's roughly the same for me as for your first responder. So I timed my own site; it was about two seconds faster in loading than yours, but it's not as heavily reliant on downloads from external sites as is yours. You might time your own - from the time you hit the button to the time it finishes loading - and see if there's much difference to our timings.
PHP is not a super fast system when dealing with web sites,, by the way, although the latest version (7.x I believe) is much faster than earlier versions. At least it was for me when I changed (in my host's c-panel) from my earlier one. I cannot remember now which version it was, but it was most assuredly s..l..o..w.
Of course there is a number of other factors when it comes to perceived speeds when it comes to the Internet, but I suspect that you are au fait with those. In Jáchym's system there is a method by which you can reduce load times, and thus the bandwidth used for your users, and that is by using the "mini-menu" for individual blocks which are likely to be little used by your visitors. If you look at my site you will see three blocks with the three horizontal bar glyph. These indicate a sub-menu of blocks. The advantage of those is that they are not loaded when the index page is loaded, only when they are selected.
Ruddy 'eck, I've been waffling again.
Cheers,
Cheers,
- livejerseyweather
Hi there
Thanks for that and don't worry I waffle too!
Good points there and thanks for taking the time to reply. I will experiment over the coming weeks.
Ta from a rainy Jersey
Ethan
Ethan
- Station model: Ecowitt WS90
My site. www.nicomaparkwx.com is similar yours in that it has a large database also but I also noticed a slow down in load times about 3-6 months ago. Has nothing to do with MT I am betting.
milesb
I have a 1.4 million database entries for my site, back to early 2005, but I don't have the delay I noticed with your site. I would suspect your hosting providers end.
http://www.sunset-weather.com/template/indexDesktop.php
- dmgould
It's not a database issue. It seems to me to be a pointing issue. When it finally accesses your index.php file, it immediately points to your indexDesktop.php and the site loads quickly. Your database doesn't get involved until indexDesktop.php loads the main page and calls for data. The delay when I go to your site is waiting on your index.php file. I would check with your host support about a pointing delay.
Yeah I think for me it was a host server issue. After a long call to 1&1 with nothing being resolved it mysteriously started working as it should have. I wonder if they slowed me down since I would not fork over more money.
