Migrating to a new host
Gatewayy
Software: Weathercat
Post by Gatewayy » Sat Sep 07, 2019 4:22 pm
Has anyone has luck with this? It should be as easy as exporting and then re-importing the database and then installing a fresh copy correct? DidI miss anything?
Re: Migrating to a new host
Post by Johnny » Fri Sep 13, 2019 9:30 pm
Hi Gatewayy,
In a few weeks I will be attempting the same thing, I wondered if I could simply copy the contents of my folder with FileZilla, in my case watfordweather.uk, then simply upload the same content to the same folder on the new hosting site. Then once it's uploaded, change the name servers from the old hosting site to the new one and in theory it should carry on.
Or am I being very simplistic and nieive about this?
kd7eir
Station model: Ecowitt Wittboy
Software: FOSHKplugin
Post by kd7eir » Tue Sep 17, 2019 1:01 pm
Johnny wrote: Fri Sep 13, 2019 9:30 pm Hi Gatewayy,
You will also need to export your data from the old server and import it into the new database on the new server.
Post by Johnny » Tue Sep 17, 2019 1:14 pm
Thank you kd7eir for that information, I'll post here when I've made the move.
Gatewayy
Post by Gatewayy » Wed Oct 09, 2019 1:48 am
I ended up just doing a fresh install as I have not messed with the template since I first set things up. and I didn't need to do a database import as it appears what Weathercat worked all last night while I was asleep and uploaded all the missing data which I did not know it would do. Thus far everything is working correctly.
