Copy a working folder to another one, now not report current weather
- bthoven
- Station model: Misol WH2600
- Software: weewx
Thanks for a great template. I host it on my home server (Ubuntu, Apache) and it has been working without problem. I now just got a proper domain name and I copied the working template folder to my new virtual host folder (on same home server). I amended the main setting by pointing it to the new domain. Changed folder permission to be the same as the old one. The template shows up without problem, except the "current" block that it won't show any current weather data.
I deleted all the files in the cache subfolder; and later the template created just only 3 files instead of 6 files. The 3 files are
interactivebanner.txt, version.txt, and latestVersion.......txt.
Please have a look at the website: https://bthofen.com/meteo
Please help.
Please help.
- Asobig
- Station model: Davis Vantage VP2+
- Software: Meteobridge (Red)
Re: Copy a working folder to another one, now not report current weather
The current block shows a massage: API file not found.
Perhaps you can find the problem in "Check for problems" in the Control Panel.
- Station model: Ecowitt WS90
Check in Main Setup that the
Path: /wx/
Page URL - make sure to include the http:// !!! https://www.nicomaparkwx.com are correct. http or https.
in my case.
If you modified the index.html or .htaccess files ensure the correct path to the root. /wx in my case.
Seems to be a path issue and can not find the api.php
Path: /wx/
in my case.
- bthoven
- Software: weewx
Thanks. The path (/meteo/) and website is right (https:bthofen.com)
(https:bthofen.com)
https://www.bthofen.com right?
www
Something is wrong. I can't get to that domain.
www
You need to create an index.html in you /root to point to https://www.bthofen.com/meteo/indexDesktop.php
The directions are in the wiki at meteotemplate.com
You have it. Works now and points to the api.php file to update your database.
http://bthoven.dyndns.biz/meteo/indexDesktop.php
you left off the .dyndns.biz/ it needed that to point to the right dns.
- bthoven
- Software: weewx
The one that is not working is https://bthofen.com/meteo
Check for problem got only this error:
API file
API file not found. This means your template is not being updated.
Are you running both at the same time?
How are you sending data to your database> i.e Meteobridge, Ecowitt, WEEWX, WD, WU?
It seems you are having a path issue. Something is not directing you to the correct path. Main setup, index.html. cache, sub-directory... something.
Without knowing your details I am only guessing.
Also, remember that it takes up to 5 minutes for updates. check your cron jobs are correct, the path to the correct api.php...
OK now, https://bthofen.com/meteo/indexDesktop.php is working correctly and the other is not. You corrected a path I am guessing.
- bthoven
- Software: weewx
Thanks. I found my stupid mistake. As I use weewx meteotemplate extension to feed live data to the template. I have to change the weewx.conf to reflect the new domain:
The original config that worked for http://bthoven.dyndns.biz/meteo):
The meteo folder is in /var/www/html/ folder
[[Meteotemplate]]
password = xxxxx
server_url = http://localhost/meteo/api.php
binding = loop
New config that did not work for https://bthofen.com/meteo
The meteo folder is in /var/www/bthofen.com/
[[Meteotemplate]]
password = xxxxx
server_url = https://localhost/meteo/api.php
binding = loop
New config that works for https://bthofen.com/meteo
[[Meteotemplate]]
password = xxxxx
server_url = https://bthofen.com/meteo/api.php
binding = loop
I don't think it is an ideal config because it needs to resolve dns everytime. Not sure is it possible to use the localhost, somehow.
[[Meteotemplate]]
password = xxxxx
binding = loop
[[Meteotemplate]]
password = xxxxx
binding = loop
[[Meteotemplate]]
password = xxxxx
binding = loop
Yes, you can use Localhost, your present IP address if it never changes only. I would stick with localhost as IP addy exposes you to the outside somewhat.
I just re-read your message. Stick with the correct address to point to the dns server.
- bthoven
- Software: weewx
You mean I stick to the https://bthofen.com/meteo/api.php ?
https://bthofen.com/meteo/indexDesktop.phpbthoven wrote: ↑Fri Jan 31, 2020 7:20 amYou mean I stick to the https://bthofen.com/meteo/api.php ?
or just:
